Repairs 917.270514 14.5HP 42" Deck Craftsman Riding mower
RayMel1
Accidently i ran over some twine while mowing. I propped the front of the mower up to remove the blade and the twine, but when i put it back down the mower does nothing. no click so sound, nothing. I checked the seat switch and made sure it was depressed, still nothing when i turn the key. Checked the battery, battery is fine. Crossed the solenoid and the engine turns over just fine. Just nothing when I use the key. Do i need a new solenoid? Someone said something about a fuse, but I have not been able to locate a fuse. any help is appreciated. thanks in advance! :)
Is the deck enguaged or is the brake pushed in?
thanks for the help! it was indeed the fuse. However, NOW I have Another problem...ugh......if i start the mower it starts fine, but if i put it in gear to drive or if i engage the blades, the tractor dies.....ugh
any help here?
yup, the switch under the seat is what the problem was. I was under the impression that the mower wouldnt start at all if it wasnt depressed. thanks for the help!
