bodell1975
- May 17, 2014
- 2
Have replaced air filter, diaphragm on carb, spark plug. I have a spark, its yellow but its there. What else can I check to get this mower running? Its a Briggs and Stratton engine.
Hey Mark,
It is a Bolens/MTD push mower. Model #11A-074E065 183617
Briggs and Stratton engine, 500 series,
Model # 10T502 type 0457 B1
Code 07091454
I have also run a compression check on the cylinder, it has 80 PSI.
Do I need to check the points on ignition on the fly wheel? The spark plug has clear liquid on it, which I believe is the fresh gas, but as of right now I am at a loss what else to check on this engine.
Thanks for your time
