Berniebac
I have a lawn mower with a Briggs Mod. 92902; Type 5211-01; Code 83012505. I put a Carb Kit in it last summer after cleaning the carb good. Never got it to run well and gave up late in last season. Took it apart, cleaned again and found a spring installed on the wrong side of the diaphragm. Reassembled, checked gap on coil, filled with fresh gas and it started right up. I had it set at 1-1/2 turns out from seated. It runs smooth sitting in one spot, but when I push it downhill it starts to sputter. Runs well when mowing on the level. Sputters when pushed down hill, or side hill, but smooths out when put back on the level. I tired adjusting the carb, backing the screw out, tightening it up, but it doesn't seem to matter. Any thoughts on the cause of this? Should it be "tuned" a little better then just leaving it at 1 1/2 turns out?
