Greysquirrel`
Wife mows the grass, loves to ride the mower, trims the edges with two battery powered trimmers and it takes her forever to trim so I thought I would buy her a gas trimmer which she may or may not like.
After checking a number of trimmers and trimmer forums I have narrowed down to the three above. I know the only difference between the 225 and the 225I is the starter. Is the starter that much easier to pull to be worth the extra money? The T235 is very similar to the 225 except for the longer shaft which is solid and not a cable. The motor does not need non ethanol gas which is not a problem for me as I use non ethanol in all my power equipment and my 1998 car which is readily available in this area. Is there any good reason to buy one over the other? The price of the 225 is $200 the 225I is $256 and the shimmy is $250, not that much of a difference in price unless of course there is very little difference in the quality of the machines and features that I don't know about. I know you have to grease the cable in the Echo and grease the gearbox at the end of the trimmer of the Shimmy or so I have been told.
The Shimmy comes with 7 day return policy and a roll of trimmer string but that not the reason I would consider it.
