i have 3 'like new' kitchen countertops that i want to freestand next to my new gas grill on the deck,will the formica top hold up against the weather for any length of time or would a sealer of some kind need to be added to the countertops ?
Hey jd they are the squared edges with the seams. and currently are framed with legs and are being used as work benches(light duty) and clean work but take up to much room in the garage and basement, so that is why i'm going to use them out side next to the grill and probably use brick to set them on instead of the legs your right on the underneith side thoughdidn't think of that ..thanks
I agree with JD, your counters will swell and the joints will widen. I would consider using this temporarily, as a test if you will. If you find your using this kitchen a lot invest in a more durable,substantial surface. I would not put a lot of time and money using these tops.The problem is, usually they are made on a particle board base, the particle board will act like a sponge to absorb moisture in the air outside. I am not sure about what you could use for sealers but I think any quality latex paint applied to the underside would help seal them against moisture. As for the tops, I don't think any type of sealer or varnish would stick to the Formica worth a darn. You could probably keep the counters covered with tarps when not using them to protect against sun and water damage...
Good post..I hope others have ideas too.
I would not use any sealant as it may migrate into your dinner somehow.
Let me know when the steaks are done, i like mine meduim rare![]()
Medium well for me, thanks....:biggrin:
hey JD.... bring twall with you. Tell him to bring lots of home brew:licking:
By the time his home brew is ready to be drunk, the steaks will be charcoal.....:laughing:
