C carchisler Forum Newbie Joined May 14, 2014 Messages 1 May 14, 2014 #1 7 hp Tecumseh is pushing oil out of the breather?
P Phil G Member Joined May 7, 2014 Messages 33 May 15, 2014 #2 carchisler said: 7 hp Tecumseh is pushing oil out of the breather? Click to expand... Could you be more specific? What model number? Vertical or horizontal crank? Over filled with oil? Some have a valve in the breather assy that can stick open. Good luck, Phil :smile:
C chance123 Well-Known Member Joined Aug 14, 2012 Messages 824 May 15, 2014 #3 Been gone for a while but if your engine has a lot of hours on it, and the oil level is correct, it "might" be blow-by. Perhaps a collapsed ring? time to re-ring with a good honeing too. If cyl is beyond spec, time to bore
