Cub Cadet Mishap
harcscarkuff
I somehow managed to tangle the wires around a wheel while mowing which lead to the headlights. :confused2: Hence, they were torn out. The lawn mower immediately stopped working. Absolutely no functions are working. Is the lawn mower even salvagable at this point?
Sure. First disconnect the battery, then post the model numbers off of the tag under/behind the seat.
Just how would the headlight wires wrap around the wheel? Is if the mower is dead you got more problems then just the headlight wires. If you are going to fix it yourself start with a wiring diagram. Then it all depends on how much damage you did? If a lot of damage maybe look into getting a new wire harness? This would be very hard to know what damage was done without seeing it? Yes I hope for your sake its just a fuse and taping up some wires. 13AQ11CP0094452550 is this a serial number what model is it.
