PickerBenny
hey guys, i found the issue for the strong recoil, the blade was loose. But after i tightened it down again with all my might, it got loose, but not too bad. I repeated this twice and i even put a washer on it, still problem permits. What do i do now?? I am certain its the original bolt and blade. None of it is stripped. I put some rope down the spark plug hole and tightened down the bolts. :thumbdown:
