Oil on plug
coosmower
I have a craftsman 917.376401 mower with the briggs and stratton engine. I had mowed the lawn just a week ago with no problems and today I wen't out to start the mower up and it would not start. I pulled the plug and it was covered in oil. It is about 6 or 7 years old, is it time for a new mower?
reynoldston
Now that depends on the mower. Just try a new spark plug, less then 5 dollars. To me a seven year old mower isn't old and would still have many more years of use.
coosmower
I was told to try a new head gasket and plug. I cleaned the plug that was in it and just in two pulls it was covered in oil again.
Fish
Check the oil level, and see if the oil smells like gas.
Then drain oil and rebuild the carb....
reynoldston
Replace the plug not clean. Fish is right, check your oil level and also your air filter.
Ean
If it is over filled with oil it will do this could be the head gasket if it has low compresion could be a bad ring
coosmower
So I cleaned the plug off again put the old gasket back on and it started first pull but i noticed it was getting super hot and kind of smoked when i shut it off.
reynoldston
What gasket are you talking about?
reynoldston
And why did you remove the head? And if so why are you using used parts? As I see it you just cleaned the plug for the second time and it started for you. Just why do you think it is getting hot when you turn it off and where is the smoke coming from?
