proximus26
- Mar 27, 2014
- 11
If you were able to rotate the engine by hand in both directions then I feel either the engine was stopping due to oil in the cylinder or there is a problem with the starter mechanism. Oil running out of the muffler concerns me. Sorry about being stuck between me and my enemy, he just wants to make me look stupid. We'll get this solved together. For what it's worth, I have seen valve adjustment done the way you described, you do what works for you and your situation. Have to go to work now, won't be back until this evening, will look for your post.
Mower Doctor 78006, Rivet and Mr. Fish, you all helped me but I still need your help. I have oil in the cylinder and this is m problem. Valve seal are gone (first one, because engine start smoking dark oil now second... how to replace valve seals. As I susspected this is problem.
BTW... I guess you are are tooooo old to fight.... make it right... I`m new one here but I think you act like 5 years old, so Mr. Fish... let`s call it as past.... You ALL are great and each of you bring value and expertize to this forum. I saw it in this post. Thank you!
Please help me to tell me how to change valve seals... what part number should I get? I also need upper valve which I think is intake valve.
