Where to sharpen blade?
The better buy I would be the Magna Matic 1000 by Magna Matic @ 199.00 the Magna Matic by Stens would be the second choice @179.00
http://www.amazon.com/Blade-Balancer-MAG-1000-Maga-Matic/dp/B00FEZ6ZBE/ref=sr_1_27?ie=UTF8&qid=1396183842&sr=8-27&keywords=Blade+Balancer]Amazon.com: MAG-1000 Lawnmower Blade Balancing Instrument: Home Improvement
[/URL]
I say buy one of each that way you wouldn't wear them out as fast. It sure puts my 5 dollar plastic cone to shame. I sure am jealous.
[/URL]
Ok, Im gonna get mag 1000 under Rotary 9788 part number here soon.
Perhaps the cones would work good enough in a pinch but for my mower business I think the Magna is the way to go because the less vibration you have the better cut you'll get.
I think if I ever bought a machines that costs over 2g I would maybe invest in one of these
That's kinda my feeling. I mean if you're going to spend 8 maybe 10K on a mower is it really worth taking a chance and using a nail to balance your blades, something that doesn't work? I thought I was alright with the cone but apparently that's not the case either.
Well I bought one because I opened a repair shop, I bought mine after I had looked at several, I went with the one that a
magnet strong enough to hold up a 33" snapper blade.
When I went to work at the big shop in Louisville, the owner and all of the techs snickered when I mounted it above my tool
bench. I would have mounted it above the blade grinding station, but I thought "Screw em'"....
Within a few weeks, the techs were coming and asking if they could check their balance, and I would let them....
As I said before, their idea of a valve grinding tool was a drill press and a piece of sandpaper........................
