Toro pushmower
With what little we know about the mower, I will make a guess. It is a real old one, with the carb atop the metal tank, no primer bulb, the old auto-choke style carb. He needs to go through the carb, replace the diaphragm, and correctly preset the
choke.
But that is just a guess.
Sorry will be home later this afternoon and will get numbers posted as soon as possible. To clear up any confusion. The mower has no issues starting when it is cold. I can pull it out of the garage prime it once or twice and on the first or second pull it will fire every time. Start mowing the yard and let it warm up to full operating temperature. Shut the mower off to answer phone or move stuff in the yard and it will not start. Only when the engine is warm will it not start. Wouldn't believe it has anything to do with carb but then again I don't know. Like I said. Will get numbers posted as soon as I get home today.
So this is your mower, and this started all of a sudden? Last fall? Summer? For over a year? You are working on it for someone else? You just bought it and want to resell it?
Sounds like a Quantum. Look to the easy start choke system. Take the covers off and clean around the linkage. Clean in behind the muffler. Make sure the choke vane moves freely. Make sure the metal coil that winds up and unwinds is working. You tube has some videos on it if you look for awhile.
Naw, he mentioned priming it. these threads would be much shorter if we had the luxury of model numbers...
If its a hot start issue then it could be the metal surpressor cap breaking down on end of spark plug if fitted.
When you have a hot non start then pull the metal cap off and only fit the terminal to the plug.
If it starts and keeps starting then fit a normal rubber boot and terminal.
Three common problems with this mower, all which may be causing the hard hot start problem. One, this engine likes to over heat due to grass collecting around the cylinder. Two, carb mounting bolts loosen up. Three, carb jets plug easily. Overheating might be causing the coil to breakdown when sitting with no air flow. Loose bolts may be creating a lean hot starting mixture. Partially plugged main jet again may cause a lean hot mixture. If it came into the shop I would start by removing the shroud and make sure the cooling fins are clean and at the same time I would check the carb bolts. Reinstall the shroud and run the unit until hot. Shut down wait three minutes and try starting. If no start, I would check for spark, if I had spark I would go after the carb. I would remove the carb, clean and rebuild with new float needle and seat. If no spark I would replace the coil and repeat the test.
Engine: 123K02-0114-E1 03030156
Mower model#: 20037
Serial #: 230012926
Any chance you would respond to the other questions?
The most likely scenario is that the tank is full of old crappy fuel... or fuel that was bought from last summer or fall....
I don't see it getting much more involved than that......
It may just be that simple.........
