JDgreen
- May 14, 2010
- Threads
- 248
- 2,887
I bought one of those cheap balancers at the local hardware store and I guess it does ok.I had some rusty blades that I cleaned up with a wire wheel and then applied a coat of EZslide as a kinda experment. won't know how that goes till spring. russ
After about 40 hours of mowing my JD blades get a hard crust of grass built up on them and not even a power washer or wire wheel chucked in a drill will take the crust off, I end up using a paint spraper or razor blade holder knife to remove the stuff.
