- May 6, 2010
- Threads
- 51
- 11,396
I went back and read through the list of post and from the description of the problem you have a compression problem. Even with compression release anything below 60 would be suspect. 600 rpm should be achieveble with a rope starter, that is only 1 rev per second. the original magnetron was set up to fire above 600 rpm. the newer systems are set up for 250-300 rpm on briggs. the origian tecumseh and kohler CDI are 300 rpm systems.
Sounds like you need to do leakdown test to determine cause of low compression. Most likely valve leaking issue. I have seen valve seat not be cut square with the valve face on brand new engines. As well as improper valve clearance gaps.
