I have read as much as I could on these mowers, but wanted to see if I was heading in the right direction. I have 4 lots that I mow, 2 of which are flat, rough, and muddy at times. However I am looking to move in the next year or so but will not be over 5 acres. More than likely it will be about 2.5 acres.
So far I have looked at Hustler Raptor SD 54", Kubota Kommander ZG123S 48", and Gravely ZT XL 48". Based on what I have read the EZT transmission is not the preferred tranny. The hustler and gravely have the 2800 series and the Kubota has the 3100. Also I think I would rather have the Kawasaki motor. So I am leaning towards the Raptor SD. The dealer is close and it is a little bit cheaper than the Gravely. The Kubota's price and the fact that it does not a Kawasaki motor is a turn off all though it looks very sharp and has a few bells and whistles. Also not sure about the chain hung mowers, none of these are but to get a chain hung deck the price goes up quick. This will be used for personal use only. What advice can you give me, and I do plan to test them all. thanks
