electic clutch pto wiring Husq. YTH2348
cajunrebel82
I just replaced the drive belt on my Husqvarna YTH2348 and noticed the wiring that runs from the electric clutch to the connection near the battery is broke, My connector is still connected near the battery but the wiring to the electric clutch is gone except for 3 inches of 1 wire from the clutch. Is that the only wire that comes from the clutch (in that case I can fix it) or am I pretty much on the hook for a new clutch. Thanks for any help.
Should be two wires on the clutch one power and one ground.
Can you post a pic or tell us what color wire is there?
