buzzzmeister
I have a '97 JD F911 mower with a 23hp Kawasaki v-twin engine. I had an oil pump drive gear shear teeth at about 600 hours and the engine was given a top overhaul at the time. Fast forward a bunch of years and after another 1700 hours, I'm in the process of installing a new replacement Kawasaki engine.
Other than the oil pump incident, the only maintenance the engine ever needed was oil changes and valve adjustments & valve cover gaskets every 500 hours.
In my case, I'd say the engine was dead-nuts reliable.
