Brigs and Stratton 900 series carb
Ean
Hey guys I have a 2 in pacer pump with a 900 series b&s engine that had Ben siting for awhile and I soaked and cleaned the carb it Is not letting fuel through to the bowl I blew it out with a air compressor and it still won't let the gas through
A small spirial tipped cleaner or a paper clip would probably help clean out the jets. Make sure the float and needle are functioning properly and that your fuellines and filter are clear of obsticles
I blew it out with an air compressor and let it soak in carb cleaner and cleaned it with a paper clip straitened out still not a drop comes out into the bowl
