matt4irish
- Mar 3, 2014
- 5
OK gang, I could use some help. I have a couple old Toro S200 snowblowers that I keep mending and working. One of them decided it was time to give up the auger bearing and the bearing flange is literally rotted away at the back.
It is the old style setup with the 27-0090 shaft, 26-9740 flange, and 27-0070 bearing. I understand that Toro made a change to the setup for these and am interested in converting to the newer setup due to the cost of the 27-0070 bearing and lack of availability of the flange.
I hope to setup with the 38-8610 shaft and cap, a 38-8620 flange and a 38-7820 bearing. I'm assuming I will also need to change the spacer to a 38-8630, but will my old 23-7360 pulley fit or will I have to change out to a 49-1530 or 41-9750?
Thanks for any help you can provide.
