CajunMan89
Toro Wheel Horse model 244-5 will not start with key
I have a 1993 Toro Wheel Horse Model 244-5, model number 72040. I am using it for a project, not for yard work. I removed the seat and deck because I will not be needing them, plus, they're in the way for what I'm using this machine for. I am having trouble with the electrical and suspect it is a safety switch that needs to be disabled. The mower has a 14HP Onan OHV engine. When I turn the key to start, nothing happens. In order for it to start, I have to jump the solenoid with a screwdriver. When I want to turn it off, I have to pull the boot off of the spark plug. I am getting 12.18 Volts to everything except the blue wire that connects to the prong on the bottom of the solenoid. This wire goes to a relay in the fuse box and not to the ignition.
Again, I suspect this to be a safety switch issue. How do I disable the safety switches on this mower?
Any help is greatly appreciated!
