snowy_weather
- Feb 27, 2014
- 5
Hello
I'm hoping that someone here will be able to help me identify the type of tool that is needed to remove this flywheel. Recently I found myself in the position to acquire a Jacobsen power burst snow blower. I believe it to be manufactured around the early 80s, but there is a engine number if it is needed. Yes, I know it is older but sometimes I like older/classic stuff, and needed something to learn more about small engines anyways. Hopefully I won稚 sound too dumb... considering I have worked on car engines for quite a long time.
anyways I'm not sure if I am just looking at this in the wrong way, however I cannot seem to figure out what tool is needed to pull this flywheel. It appears the flywheel has no screw holes for a bolt type of puller, and there is not enough space between the flywheel and the case/block for a jaw type puller. So I thought perhaps maybe a knock off type remover was needed, but on closer inspection there appears to be a small center holding clip around the crankshaft, as if there needs to be some type of tool that would press the flywheel down slightly in order to remove the small clip. But I'm not actually for sure what tool that would be or if my observation on how to remove it is correct. Unfortunately, the only thing that keeps popping into my head is a steering will lock plate compressor. Which I know is absolutely incorrect. :laughing:
I have linked some photographs of the flywheel, hopefully you will be able to see the small center clip that I am referring to that is around the crankshaft that I believe is what is preventing the flywheel from coming off. But it may be that I'm just not thinking in the right logical approach, so hopefully the photos will provide more information about what type of puller is needed or approach.
Any help or ideals would be much appreciated.
Thank you for your time, help or ideals.
sorry about the extremely large pic's, but I'm usually thinking a long the lines of......" if you can see it then you might be stumbling in the dark for a answer."
