- May 6, 2010
- Threads
- 45
- 11,145
FYI Kawasaki FC540V single Cyl. on lx186.. had lots of odd running intermit problems, with gas leaking from overflow tube behind carb, sometimes a lot, other times seemed to work with out leaking.. ended up being bad float(plastic).. tried to repair by drilling hole draining drying, etc. then resealing, but didn't use the correct sealant?? bought new float $25+~ and working fine since., approx 1 year. If had to do again would have tried sealing with JB Weld, maybe would have saved a few $$ as i have repaired Plastic Radiator tanks, etc. and worked great.
I have used a hot glue gun in a pinch for plastic floats. Gas doesn't soften the hot glue. Repaired a float on a customers generator 3 years ago, during a week long power outage following an ice storm. Genny is still running without issue.
