Mike88se
- Oct 11, 2013
- Threads
- 76
- 739
Hi, first time in this forum. I got a couple of Snapper mowers in a trade. One is a Ninja p217017 with a FJ180v and the other is a Hi Vac powered by a Briggs Intec w/ a bent shaft.
First question is what is the difference in the decks? Other than the decals they look the same to me.
I used the Ninja on a couple of lawns yesterday. I had it with me as a backup for my Exmark 21. The exmark blade brake lever was acting up so I got out the Ninja. I swapped the bag and attachment piece that was on the Ninja for the mulch attachment that was on the Hi Vac. The quality of cut was okay but not great. The blade is sharp but it's just a normal blade, not the Ninja blade. I'd try a Ninja blade but they are pricey and I don't plan to keep this mower. I know you guys are partial to Snappers but the exmark is my go to 21 and I have a Honda HR217 as a backup. Another thing I was curious about is that the ground speed seemed very slow. Is that normal for this mower? I understand how the disc drive works and everything seems to be good and adjusted well. Maybe I'm overlooking something.
The Hi Vac engine has a bent shaft. Is the resale value enough to justify putting $120 into it?
