Ground mowing speed
trace
How would the straight line mowing speed of a Toro Grandstand compare to a 4500 Ventrac and a Kubota BX25D with a mid mount mower?
How can you compare? There not even close to being the same machines.
It would all depend on the skill level of the operator. Also like Ric said they're not comparable in terms of steering and ground speed. So it would just take time and practice to maintain straight lines at a relatively high ground speed.
Top mowing speed for my Grandstand is 8 mph, you don't need anymore than that I mow at half that speed. If you mow at top speed you sacrifice cut.
