scag 36" walk behind belt drive spark problem
viper1
i had to replace my motor on my scag and everything went together well except the wiring to the coils. the mower and the previous motor had a two black wire and one white wire setup. but now i have two black wires from the harness and only one black wire for the motor now and of coarse still one white wire apiece. how should that wire up? putting both black wires together does not work so i need help!
Fish
Post the brand and model numbers off of both engines, and we should be able to help.
viper1
old motor- Kawasaki FB460v-ES36
e/no FB460va98455
new motor- Kawasaki FH451v-as09
e/no FH451va62094
my scag- model# sw36-13ka
Fish
buykawpower.com
Well you have went from an older single cylinder, to a newer twin cyl. engine. The older engines used a "trigger unit" that had replaced the old points/cond. system.
The newer engine should just have one wire to each coil for the "kill" circuit only, and that one should be wired into the "Kill circuit" on your old mower...
You need to be carefull, as mis-wiring these parts can destroy expensive parts. So I am not real comfortable on going on much further, as those coils are pricey.
It might be wiser to take it to a local shop that knows what they are doing, as they will have the benefit of having the mower in front of them.
Also, most newer engines have pesky wires going to carbs which further muddy up the engine swap.
viper1
buykawpower.com
thank you i have hooked everything but that up so it shouldn't cost to much to get that hooked up thanks i will take the advice and take it to the shop.
Fish
Well, it shouldn't be too hard for someone with some experience. We don't have the benefit of having it in front of us here, so you would likely get a lot of bad advice.
