davbell22602 Lawn Addict Feb 8, 2014 #1 Remember to check your friction disc drive setup on your snowblower or it will cost you. See pic below
M msaeger Active Member Feb 17, 2014 #2 davbell22602 said: Remember to check your friction disc drive setup on your snowblower or it will cost you. See pic below View attachment 19277 Click to expand... How do I know if I have this setup? How do I check it if I do? Last edited: Feb 17, 2014
davbell22602 Lawn Addict Feb 18, 2014 #3 This seen on the 2 stage snowblowers. Check by draining the gas, then tipping it on the bucket, then remove the bottom cover.
