Howdy Doody
I got the cub this past April now with over 900 hours on it starts and drives just as if it was new.
It gives a very good cut.
My brother inlaw came to help me with a few yards with his D130. He could not hang with me in the tall thick grass.
With over 900 hours I have had to replace
Both front tires
Spindle bearings.
3 blade belts.
And the normal things like blades, oil , filters.
Have not had to replace drive belts and they still look good.
Hold hills better than any riding mower I have used.
Every year I buy a new mower this was my first cub cadet and the best mower I have used in this price range. I will use it again this year rather then buy a new one.
I have not used the craftsman but as a rule I like craftsman.
IMO john Deere makes very good tractors for the farm but cheap mowers.
I have also read from various blogs by so called "experts" that say that the Kawasaki in the Cub is not the same quality as the Kawasaki's that are in the commercial models. I would have to call duh on that, but would still thing even the lower end Kawasaki would be better than the Kohler or the Briggs. This same "expert" had also wrote, after I mentioned the Cub has mostly bad reviews due to deck problems that the factory had re-routed the belts "incorrectly" on about a 1000 decks before they found the problem and solved it. Ever heard any of these rumors?
