exotion
- Jun 24, 2012
- 3,444
I was going through my old toro noticed it was leaking a litter oil at the main seal so I ordered new gaskets replaced all gaskets, readjusted valves, cleaned carb readjusted throttle plate and mixture screw, new oil, new fuel filter and lines, new belts, new brake pad, took trans apart and put new synthetic grease new blade cleaned whole machine.
My mod was the air box was warped and inadequate so I replaced with a Honda air box I had laying around the Honda box had a couple extra holes I sealed and plugged and painted the old worn paint thing runs and looks new I love it also I added the wear plate kit because the aluminum notches were getting to worn
