Fish
Looking at the front wheels on your unit, has the oilite type "bushings" so they have no seals, I misread your post. I still cannot imagine 1/4" flat spots on either though
as the wheel is rotated constantly in the bushings, so if they had bad wear, they would just be wallowed out badly and real sloppy. You might contact JD directly
and see if they had any problems, but if the parts were replaced by someone other than a dealer, I doubt that they would do much. See if you can round up the parts
and take some pics, and I will show them to our local JD dealer and see if he has had anything similar.
