winter rebuild toro 20622 with mods
exotion
I was going through my old toro noticed it was leaking a litter oil at the main seal so I ordered new gaskets replaced all gaskets, readjusted valves, cleaned carb readjusted throttle plate and mixture screw, new oil, new fuel filter and lines, new belts, new brake pad, took trans apart and put new synthetic grease new blade cleaned whole machine.
My mod was the air box was warped and inadequate so I replaced with a Honda air box I had laying around the Honda box had a couple extra holes I sealed and plugged and painted the old worn paint thing runs and looks new I love it also I added the wear plate kit because the aluminum notches were getting to worn
Looks great! :thumbsup:
I did notice the engine colors but wanted to be nice so I said nothing about it
Like the mower I also did a re build of a toro walkbehind this witer but mine was. 37 inch floating deck walk behind I re painted it re packed grease in spindles an added a few new parts I should get 5-6 more years out of this mower for sure :thumbsup:
I decided that the bald tires weren't good enough and wanted to try the mountain bike tires they look super cool and drive like a dream
They look cool but I don't get calling them "mountain bike tires".
Do you like those wheels for a commercial mower? I would think you would want wheels with a grease fitting so you don't have to take them off to lube.
I have a couple of mowers (one for parts) with the same deck but powered by the two-stroke Suzuki. :thumbsup:
