Fish
Sounds like the exhaust valve is leaking badly, a complete valve job is probably needed. With the plug back in, rotate the flywheel backward to check the compression.
You should reach a point that the flywheel will stop, and rebound back, with some bounce, it is a quick way to check an engine's compression.
