Fish
Two things are common in the l-head twin that cause hard cranking. First, the starter's top bushing gets worn out and gets a lot of slop in it, I replace the bushing
using an oilite sleeve from the hardware store and a little bit of redneck craftsmanship. While apart, buff the contacts of the starter.
The other issue that is common, is a buildup of carbon in the combustion chamber, which just requires the removal of the heads and a stiff wire brush, the gaskets
will likely come apart, so those would need replaced as well.
It is highly doubtful that a valve adjust would cure your problem in this instance, it mainly applies to the OHV models.
