Iron Falcon 72
I need a blade that will take down up to 1"-2" brush and woody stemmed weeds? There seem to be several different types. I'd like to stay away from the chainsaw type. Any good recommendations? Thanks.
I thought you get that when you buy the trimmer new?
I purchase the FS 90 and 110 and it never came with mine. It's comes as accessories or attachments.
I bought a FS85R back in spring of 2000 and it came with it.
If your cutting 1"-2" brush you'll probably want the Stihl 7.9" scratcher tooth blade. It will easily take down anything in that range. You'll also have to but the kit or adapter to be able to mount the blade to your machine. Blade runs about $23.00 and the kit around $20.00 It should be the 1"diameter.
