Engine Cross referenceing oil filters
Joshknuckles
Does anyone know of a good cross reference guide to use to cross an oil filter for my 17.5 hp kohler motor
BKBrown
Have you tried the major filter manufacturer sites or Carquest / Napa -- ?
Joshknuckles
I wanted to go to Walmart and get one because all of our parts place
Joshknuckles
Are closed on Sunday and I really need to get my grass mowed
BKBrown
for Kohler 17.5
K&N lists HP-1002
Wix lists 51348
Usually the owners manual will give you filter numbers and the store will have a book to look up cross reference.
RobertBrown
I use the wix site. Napa uses the same numbers with a different prefix. Once you have the numbers you can get the filter. next time:ashamed:
motoman
Measure the O ring seal diameter. Then the screw thread pitch/ dia with a thread gauge. Better yet, find a matching bolt to take to an auto parts store. Open and try some filters 'til one fits. I went bigger (deeper can) when when I did this for the Intek.
You must overcome the fear factor that Briggs sets that their $15 filter has magical cooling powers.
If your current oe filter is a 52-050-02 then a stp 3614 will work.
de dee
I have a PGT. 9,000 with a kohler Eng. SV 735 type 3030 and the oil filter from a Hyundia elantra 1.8 cc eng. fits ,. I wish I could find a longer filter, it would make it easier to take it off and on,. on the car and the tractor,
