What price should I ask for my 2013 Craftsman 42'' 24hp Turn Tight Riding Mower?
wdrdoctor
What price should I ask for my mower? I want to list it on craigslist. I will offer my mower with free delivery,and a full tank of gas.
_____________________________________________________________________________________________________________________
2013 Craftsman 42'' 24hp Turn Tight Riding Mower. ( Sears Item# 07128856000 | Model# 28856 )
I bought this mower brand new at the end of July for $1,800.00
It now has only 18 hours total.
I have had no problems at all with this mower.
I did add 2 brand new accessories to this mower.
1 - Mulch Kit
2 - A front dual bumper bar.
Specifications & Dimensions
Cutting Deck & Blade:
Blade Material: Steel
Blade Type: 3-in-1
Blade Width (in.): 2.5
Cutting Deck Material: Stamped Steel
Cutting Deck Nose Roller: No
Cutting Deck Style: Side Discharge
Cutting Deck Type: Precision cut
Cutting Height Adjustment Increments: Spring assist
Cutting Height Adjustment Type: Spring Assisted Lever
Cutting Height Maximum (in.): 4
Cutting Height Minimum (in.): 1.5
Cutting Positions: 6
Cutting Width (In.): 42
Deck Thickness (Gauge): 13
Deckwash System: Yes
Discharge Location: Side
Number of Cutting Blades: 2
Number of Deck Anti-Scalp Gauge Wheels: 4
Controls and Features:
Blade Engagement Type: Manual
Blade Lift: Manual
Speed Control: Fender Control
Dimensions:
Wheelbase (in.): 48
Product Overview:
Color/Finish: Red
Commercial/Residential: Commercial
General Warranty: 2 year full, 5 year frame limited lifetime front axle
Item Weight (lbs.): 518
Recommended Terrain: Flat with some hills
Recommended Yard Size: Up to 2 acres
Terrain Type: Flat, Hilly, Obstacles
Chassis:
Frame Material: 12 ga. steel
Frame Type: Channel
Front Axle Material: Cast iron
Number of Wheels: 4
Step Thru Frame: Yes
Handling & Operating:
Brakes Type: Disk
Cruise Control: Yes
Electric Clutch For Attach.: No
Hour Meter: Yes
Steering Type: Conventional
Steering Wheel Type: Standard
Drive System:
Maximum Forward Speed (mph): 5.2
Maximum Reverse Speed (mph): 2.9
Mow in Reverse: Yes
Number of Forward Speeds: Infinite
Number of Reverse Speeds: Infinite
Shifter Location: Pedal control
Turning Radius (in.): 6
Turn Tight: Yes
Motor-Engine:
Air Filter Type: Auto-type paper
Cooling Fan: Yes
Cooling System Type: Fan-cooled
Cylinder Liner: Cast iron
Electronic Ignition: Yes
Engine Brand: Briggs & Stratton(r)
Engine Cycles: 4-cycle
Engine Lubrication System: Full pressure
Engine Series: 24 HP Vtwin
Engine Displacement (cc): 724
Horsepower: 24
Number of Cylinders: 2
Oil Filter Type: Spin On
Overhead Valve Engine: Yes
Throttle Adjustment: Remote
Wheels & Tires:
Anti-Scalp Gauge Wheels: Yes
Front Tire Size: 15 x 6 x 6 in.
Rear Tire Size: 20 x 8 x 8 in.
Wheel Grease Zerks: Yes
Accessory or Attachment:
2 Bin Bagger Part Number: #24891/#24897
3 Bin Bagger Part Number: #24892
Accepts Bagger: Yes
Dozer Blade Capable: No
Electric Lift Kit Capable: No
Ground-Engaging Attach.: No
Hauling Equipment: Heavy Hauling, Light Hauling
Mulch Kit Included: Sold Separately
Mulch Kit Part Number: #33742
Snow Blade or Thrower Capable: Snow thrower, Snow blade
Fuel System:
Fuel Capacity (gal.): 3
Fuel Gauge Location: On Tank
Fuel Type: Gasoline
Convenience:
Adjustable Seat: Yes
Cup Holder: Yes
Headlights: Yes
Gauge Accessory:
Battery Ammeter: No
Convenience Features:
Power Steering: None
Certifications:
CARB Compliant: Not Compliant with Cali. Air Resource Board
Seat:
Arm Rests: No
Others:
Tractor Grade: Yard Tractor
Is there a reason you want to sell it? Its still has to be like new. So I would say close to what you paid for it. Its just like anything once you use it its used. You know what you want out of it so why not start a little on the high side and you can always come down on price if need be.
i would list it at 1700 and take no less then 1500 for it
Well right now it is listed here for $1614.89 online at Sears.
spin_prod_784461112
They still hsve stock at my store at this price. I would take off around 20% for it being used from the sale price and offer it for $1300. Otherwise most would buy a new one.
Good Luck!
If buying online they also offer an extra 5% off Tractors over $1499 Sold by Sears. Valid til 11/27 5pm CT. This brings the new price down to $1534.15 + tax.
spin_prod_784461112
Good Luck!
If buying online they also offer an extra 5% off Tractors over $1499 Sold by Sears. Valid til 11/27 5pm CT. This brings the new price down to $1534.15 + tax.[/QUOTE]
plus tax and all that crap ....I wouldn't take any less then 1500 buts that's me ..Plus u added Extras to it
I've had it listed for about 7 days now,and haven't had any people respond yet.
I assume that this time of year is very difficult to sell lawn mowers.
I just dropped my price down to $1,350.00
they are hard to move this time of year ...Thats why Sears is dropping the price also to move out old stock for the new stuff coming out in the spring ..the prices will go back up in the spring
Anything thats bought in retail store loses half its value regardless what the condition is. So I'd list for $1000/bo if it was me.
We get allot more then that up here ..But then again we pay more we have GST PST and these stupid taxes ..I see some of the deals u guys get down there we pay about 1000 1500 more depending on what it is
