What price should I ask for my mower? I want to list it on craigslist. I will offer my mower with free delivery,and a full tank of gas.
_____________________________________________________________________________________________________________________
2013 Craftsman 42'' 24hp Turn Tight Riding Mower. ( Sears Item# 07128856000 | Model# 28856 )
I bought this mower brand new at the end of July for $1,800.00
It now has only 18 hours total.
I have had no problems at all with this mower.
I did add 2 brand new accessories to this mower.
1 - Mulch Kit
2 - A front dual bumper bar.
Specifications & Dimensions
Cutting Deck & Blade:
Blade Material: Steel
Blade Type: 3-in-1
Blade Width (in.): 2.5
Cutting Deck Material: Stamped Steel
Cutting Deck Nose Roller: No
Cutting Deck Style: Side Discharge
Cutting Deck Type: Precision cut
Cutting Height Adjustment Increments: Spring assist
Cutting Height Adjustment Type: Spring Assisted Lever
Cutting Height Maximum (in.): 4
Cutting Height Minimum (in.): 1.5
Cutting Positions: 6
Cutting Width (In.): 42
Deck Thickness (Gauge): 13
Deckwash System: Yes
Discharge Location: Side
Number of Cutting Blades: 2
Number of Deck Anti-Scalp Gauge Wheels: 4
Controls and Features:
Blade Engagement Type: Manual
Blade Lift: Manual
Speed Control: Fender Control
Dimensions:
Wheelbase (in.): 48
Product Overview:
Color/Finish: Red
Commercial/Residential: Commercial
General Warranty: 2 year full, 5 year frame limited lifetime front axle
Item Weight (lbs.): 518
Recommended Terrain: Flat with some hills
Recommended Yard Size: Up to 2 acres
Terrain Type: Flat, Hilly, Obstacles
Chassis:
Frame Material: 12 ga. steel
Frame Type: Channel
Front Axle Material: Cast iron
Number of Wheels: 4
Step Thru Frame: Yes
Handling & Operating:
Brakes Type: Disk
Cruise Control: Yes
Electric Clutch For Attach.: No
Hour Meter: Yes
Steering Type: Conventional
Steering Wheel Type: Standard
Drive System:
Maximum Forward Speed (mph): 5.2
Maximum Reverse Speed (mph): 2.9
Mow in Reverse: Yes
Number of Forward Speeds: Infinite
Number of Reverse Speeds: Infinite
Shifter Location: Pedal control
Turning Radius (in.): 6
Turn Tight: Yes
Motor-Engine:
Air Filter Type: Auto-type paper
Cooling Fan: Yes
Cooling System Type: Fan-cooled
Cylinder Liner: Cast iron
Electronic Ignition: Yes
Engine Brand: Briggs & Stratton(r)
Engine Cycles: 4-cycle
Engine Lubrication System: Full pressure
Engine Series: 24 HP Vtwin
Engine Displacement (cc): 724
Horsepower: 24
Number of Cylinders: 2
Oil Filter Type: Spin On
Overhead Valve Engine: Yes
Throttle Adjustment: Remote
Wheels & Tires:
Anti-Scalp Gauge Wheels: Yes
Front Tire Size: 15 x 6 x 6 in.
Rear Tire Size: 20 x 8 x 8 in.
Wheel Grease Zerks: Yes
Accessory or Attachment:
2 Bin Bagger Part Number: #24891/#24897
3 Bin Bagger Part Number: #24892
Accepts Bagger: Yes
Dozer Blade Capable: No
Electric Lift Kit Capable: No
Ground-Engaging Attach.: No
Hauling Equipment: Heavy Hauling, Light Hauling
Mulch Kit Included: Sold Separately
Mulch Kit Part Number: #33742
Snow Blade or Thrower Capable: Snow thrower, Snow blade
Fuel System:
Fuel Capacity (gal.): 3
Fuel Gauge Location: On Tank
Fuel Type: Gasoline
Convenience:
Adjustable Seat: Yes
Cup Holder: Yes
Headlights: Yes
Gauge Accessory:
Battery Ammeter: No
Convenience Features:
Power Steering: None
Certifications:
CARB Compliant: Not Compliant with Cali. Air Resource Board
Seat:
Arm Rests: No
Others:
Tractor Grade: Yard Tractor
1 - Mulch Kit
Blade Type: 3-in-1
Blade Lift: Manual
Dimensions:
Wheelbase (in.): 48
Product Overview:
Color/Finish: Red
Chassis:
Frame Type: Channel
Number of Wheels: 4
Brakes Type: Disk
Cruise Control: Yes
Hour Meter: Yes
Drive System:
Mow in Reverse: Yes
Turn Tight: Yes
Motor-Engine:
Cooling Fan: Yes
Horsepower: 24
Wheels & Tires:
Accepts Bagger: Yes
Fuel System:
Fuel Type: Gasoline
Convenience:
Cup Holder: Yes
Headlights: Yes
Gauge Accessory:
Battery Ammeter: No
Certifications:
Seat:
Arm Rests: No
Others:
