briggs
- Sep 19, 2010
- Threads
- 17
- 720
Here are the facts about propane as a motorfuel:
Like gasoline LPG is flammable, but has a much narrower range of flammability. LPG has a much higher ignition temperature of 920-1020 degrees vs. 80-300 degrees for gasoline. LPG will only burn with an air-fuel ratio of between 2.2% and 9.6% and will rapidly dissipate beyond its flammability range in the open atmosphere, making ignition unlikely. LPG tanks are tested to a minimum 4 times normal operating pressures and are 20 times more puncture resistant than gasoline tanks.
I don't know what else I can tell you other than the facts don't support your fear of "a bomb strapped to your behind". My wife is deathly afraid of spiders but if she'd learn about them she wouldn't be so afraid. Personally, spiders don't bother me. I've been bitten seven times by widows and survived. No, it wasn't pleasant, but I turned out just f,f,f,f,f,fine...:confused2:
propane dose not scare me but I don't want to sit on a tank of it to much to go wrong with it your talking about machine's that will be bounced around smashed into stuff people cobbling stuff making there own repairs Parts wise it will cost more its all about money people are cheap when they get the bill to fix there propane EQ they will have a heart attack man trust me I have seen it why do u think people throw there BBQs and construction heaters away because they cost to much to repair ..Now I fix mine but not everyone can
