Ric
- May 7, 2010
- 5,765
I don't know what kind of mower you are running and I don't know what kind of zero turns they are running but my ZD 326 will take you to about any angle you got the guts go take it. I have never run a mower of any kind that will work on any steeper hill. Across or up and down. I have a ZG 222 as well. It does pretty good also but it will slide some especially trying to turn right going downhill if it is too steep.
At 1,700 pounds and more money than it's worth the 326 sucks on wet hills or wet ground period leaves to any tire tracks.
The mower you choose to use should do any job that comes your way.
Yes I cut hills for guys that have scag and kabota ZTRs they are just to heavy when the ground is wet. They just turn everything to mud.
To put any ztr on a 45 degree hill is foolish
They are not made for it.
jekjr I know your partial to your Kubota's but keep in mind the mower is only rated at 15 degrees the same as most lawn tractors, to mow anything greater than 15 degrees you would be depriving your engine of proper lubrication. Kawasaki engines are rated for up to 25 degrees but even they say not for extended periods. you both showing your stupidity.
I have to agree somewhat with Carscw in the fact that anyone who mows with a ZTR, any ZTR knows they will leave tracks and ruts on wet ground and there not worth a flip on wet hills because you have no control of the mower and all they do is tear up turf.
When it comes to mowing hills, the fact is to mow up and down hill on any mower is insane because you have no control of your mower especially turning down a hill and it puts not only you at risk but also the client your working for at risk.
