Hello,
I recently purchased a used 17 HP Craftsman LT 1000 with hydrostatic transmission. When mowing I noticed the mower occasionally slips out of gear for about a second and then reengages. It only does this on a downgrade (downhill) and very slight downgrades will cause it. The rest of the time the mower runs strong on a flat surface and uphill. The transmission isn't making any grinding noises or unusual sounds. I checked the drive belt and it looked ok but I sprayed it with belt dressing anyway with no improvement. I was wondering if anyone had this issue before or knew of a fix? Any help would be appreciated. Model #917 271661
Thanks!
Thanks!
