reynoldston
- May 23, 2011
- 5,705
Like I said check choke first. Your fuel pump has a one way valve in it. This hold fuel pressure to the carburetor so when you have a cold start you don't have a empty fuel line if the fuel bleeds back into the tank. If this fuel pump valve go's bad it will make for cold hard starting.
