djdicetn
- Sep 3, 2012
- 2,193
I recently purchased and installed a Hex Striper Kit on my 2012 Gravely Pro-Turn 152. For the installation I had to jack up and remove both rear wheels to drill out some holes in the frame behind the tires to install the mounting bracket for the striper roller. The instructions with the kit were very clear and provided bolt torque specs for all of the kit installation hardware. But......when I went to put the rear wheels back on the ZTR, I could not find ANY specs in my owner's manual that gave the ft/lbs torque specification for the rear wheels on the Pro-Turn. When I removed them, the resistance(compared to removing the lug nuts on an automobile that are normally torqued to 100-110 ft/lbs) was "about" half as hard to remove. Most of the torque specs for the striper kit were 31 ft/lbs, so I kinda "guessed" that the torque for the rear wheels should be approximately 50-60 ft/lbs.
Are there "universal" torque recommendations for the rear wheels of "any" ZTR or do they vary from manufaturer to manufacturer? Should I contact Gravely to get their recommended torque specification? Last thing I want is for one of my rear wheels to come off while mowing....or to damage my Hydro-gear trannies by over-torquing the wheels:0(
BTW, I also torqued them in the "auto application" recommended "star pattern" for a consistent torquing of the wheel to the tranny hub. IMHO, this was a major oversight in the Gravely owner's manual(almost every owner at one point or another will remove the rear wheels and need this important spec.
Any advice or guidance will be greatly appreciated. Thanks!!!!!
