Fish
- Aug 2, 2013
- 5,145
How we got here is kind of irrelevant, but here's what happened. The mower wasn't starting. The primer bulb was shot, and the tank and carb were full of rust. Since I needed a new tank, I decided to pay just a bit more for the tank/carb assembly, since I didn't feel like rebuilding the carb. I accidentally bent the governor link when I installed the new tank/carb, but didn't realize it until later, when I couldn't get the motor to idle down. Rather than try to guess the correct shape/length of the old link, I bought a new one (only $6). Mind you, at this point the engine ran GREAT, just too high... Well, after installing the new link, I was confident I was finished with the whole thing, but that's when I adjusted the governor incorrectly, because the throttle lever had jumped the stop when I tightened it. That's when I started having the surging/sputtering/misfiring thing. After realizing what I had done, and fixing the throttle lever and readjusting te governor, I still have the problem, even though it's much better. That's why I was wondering if running the motor with the governor way out of adjustment could have actually damaged the governor. But the carb is new and clean, so that's not the problem. All parts are genuine OEM, btw.
Run it!!! As long as it doesn't overspeed!!!! The sputtering and misfiring is probably old gas/crap still in the system.
