JDgreen
- May 14, 2010
- 2,887
This should apply only to those who have an engine where you can vary the operating speed, it does not apply to mowers that run at a set, constant speed.
Every mower or tractor I have owned that had a throttle that controlled engine speed clearly stated in the manual "always mow at full engine speed", but many times if I was mowing dry grass or grass that wasn't hard to cut, I never used more than 80% of throttle. Supposedly using 80% of throttle gives the engine a workout (especially important in a small diesel) but doesn't stress the engine enough to cause problems down the road. I posted the same query on TractorbyNet several years ago and the responses were mostly "run at 80% maximum throttle when you can and save the remainder for an ugly day" :laughing::confused2: which I interpret as meaning when you have to cut fast to get ahead of the rain that is coming give it full throttle. Any thoughts?
