jim282
Today, I brought home an old (1980s?) model Sears 7/25, electric start, rear engine, rider. Been sitting around for a long time, but not in too bad of shape. As per usual, won't start and I could use some help. Engine is a Tecumseh #143-286132.
Spark plug is getting wet so I assume carb is at least putting liquid through to the cylinder, but no spark. Used a spark tester and couldn't even get a weak spark. Removed top from motor to get to the coil and it appears that is under the flywheel (please tell me it's not so).
That's where I stopped for the day. Any help on testing procedures would be greatly appreciated. Thanks, Jim.
