N Nitro10 Forum Newbie Sep 17, 2013 #2 jose cruz espnoza said: john deere l100 backfires what can be the problem Click to expand... Check you fuel selinoid, it is a anti backfire that is screwed into the carb bowl. Also put a inline cut off in the fuel line.Then before you shut it off turn off the inline cutoff first, let it idle for a minute, then cut off engine
