hustler super Z turns off when you make a right turn
schwing
mower just dies when you make a right turn no matter if blades are engaged or not. Will start right back up like nothing happened. Any ideas whats wrong.
Probably just a layer of water in the bottom of the carb.
Or else it is some bare wiring grounding out.....
If its only right turn I would check for worn wires as mentioned above. Have you checked your hydro fluid on your right side? And safety switches are another thing to check
