616z will not start
sas1959
A friend gave me a 616z that had set out last winter, uncovered. Now it will not start......just cranks over. There's no fire t the plugs. I have changed the coil and still no fire
How do you know that the coil was bad?
New coil and still no spark means there is a safety switch problem or a wire shorting out.
Unhook the kill wire from the coil and start the engine.
