exotion
I wasn't referring to the Gravely having equal or better "components"...but simply said you could get a 60" Gravely for what you pay for a 48" Scag. More cut per pass versus a few "Industrial"(Scag) components instead of Commercial"(Gravely) components. Admittingly, the upper line Kubotas and the Scags are a step above the Gravelys in regard to that perspective but it's only feasible if you can afford a second mortgage for the real good Kubotas or Scags. My Gravely dealer also sells Scags, but when I compared price tags I...............:0)
P.S.
And the OP is just cutting 5 acres....not mowing yards for a living and I can't see the justification for a Scag/Kubota expenditure for "residential" use.
5 acres is quite a bit..... and the justification is longetivity...
