dhutch80
- May 6, 2013
- 2
Hello, I've read a lot of threads but couldn't find my answer so decided to post. I have a Craftsman EZ-MULCH 42" 42E707.. The tractor always ran great but I left it sit out for one winter, now having all kinds of problems getting it running! It used to fire up immediately and never had any problems.. But I moved and needed this mower again and tried to get it started, but it was just cranking and not trying to fire up. I could only get it running when I'd put gas in the top of the carb, then the gas would pull up through the filter while running for several seconds, then stall and the gas would run back down.. I eventually fried the starter messing with it, so I replaced the starter, now I only get a single click when I hit the key. It sounds like it's coming from the voltage gauge, but can't really tell. I ordered a new solenoid, but it also looks like the ignition switch is corroded more than it should be also! It ran great last year, and was cranking over fine this year while trying to start it.. bit more just a click! Anyone have this problem and have any solutions?? Any advice would be GREATLY appreciated!!
Thanks!
Thanks!
