metz12
- Nov 24, 2012
- 892
So, I have never dealt with a string trimmer carb before so I figured i would ask the pros. i replaced all the lines and when i hit the primer bulb gas shot out of the hole on the plate so i took it off to see the problem (pic 1). the gasket under that plate has a whole in it and around the edge of the gasket. i got the thing running on full choke but not on half choke or off. do you guys think the carb would have needed cleaning anyways? i can get a new carb on ebay cheaper then a rebuild kit. its a walbro wt628. thanks in advance.
